So how do i bolt this down? :S
So i want to do a pull config for my 240 rad @ the bottom of a Switch 810.
Ive only been given these with the rad package:
Do you guys know what i need and how long?
Thanks
Getting close to building the loop :)
You'd need to get some short M3 screws, or just go for push/pull instead.
as said, either 5mm long m3 screws or do push / push+pull
Thanks both for the reply. Push+pull isnt an option right now as ive run out of budget for the system + i dont think there is a massive performance jump
But anyway, do any of you know where i can get a M3 screws, 5-10mm long in person? Like Tesco for example :S Asking because i dont wanna drive around endlessly trying find them haha + buying them online isnt feasable because i need it ASAP :lol:
Thanks again
also look to radio control aero/car shops. telephone also works when
driving distances and not looking to come up empty.
couldn't he just put the fans on the bottom and push into the rad?
That's probably what I'd do to be honest.
Just a bit of advice - for me, it made it a lot harder to bleed the loop with the rad in the bottom. You'd be better off putting it in the front and moving hard drives to the optical bays or somewhere else
