Smallest mini itx case to fit a custom loop?
The_Governour
What would be the smallest mini itx case that could fit a custom loop, with a minimum of a 240 rad - and even better with a 240 + 120/140 rads?
I know the 250D can house a 240 slim and a 120 at the front and the 250d is quite small. I would not count the prodigy as its quite a big case for mini ix.
2000792
Don't know if the corsair air 240 is to big for you, but it should be able to hold 2x240 (38mm thick) rads in the front compartment, assuming you use an itx motherboard, and if you want to a 120 thin rad in the back compartment. (I've had a 140 in there but wouldn't recommend it).
Don't know if the corsair air 240 is to big for you, but it should be able to hold 2x240 (38mm thick) rads in the front compartment, assuming you use an itx motherboard, and if you want to a 120 thin rad in the back compartment. (I've had a 140 in there but wouldn't regionens it).
I would say that the 240 air is a bit too big. I am just asking your guys opinions about a good mini itx case that is small and is pleasing to look at with 240 and if possible a 120 for rads and a custom loop.
I would count out the Evga Hydro as the cable managment is horrible and to make it decent looking then you have to custom build it.
What about that Ncase thing?
Just from looking at mine, I don't think you can get anything more than 1x 240 rad in there, even with that people have problems getting a res in too and either mount it externally or go for a rad/res combo.
Hmm what about getting one of those expandable AIO loops and using the CPU block/pump/res from that? Or would they be too tall? Would certainly be amazing if you can pull it off!
I would love to try an expandable AIO´s but here in Spain I cant seem to get my hands on the old H220 as I think the new h220x wont fit in the 250D or the M1Ncase - any one know???
Also here in Spain i dont know why but there are no one that distributes the H220x - so any other good expandables AIO´s worth mentioning?
