sheroo
I've been wanting to do a couple of projects for a while, and now Christmas is out of the way, I'm gonna finally get my finger out and get some stuff done. I spend too much time doing research and looking at other peoples' projects it’s about time I did something.
The first project is a mini project – I want to give my current rig a facelift. I’m happy with all of the hardware that I’ve got and how it performs, I just want to change the look of it, and see if I can make it slightly quieter and light it up nicely. For reference here is my current rig:-
Since that pic was taken, I’ve changed the reference Sapphire HD 6950 for an MSI TF3 HD 6950. The difference in noise levels is unbelievable and it dropped 10C at idle.
I bought this case ages ago when it first came out, and it’s been sitting under my desk – CM Storm Enforcer.
Two rigs have inspired my choice of fans, KiiYzOo_Skeleton rig and Xigmatek Elysium Workstation Build. They both use the Xigmatek XLF fans and imo look simply awesome. Although I was a little concerned that KiiYzOo recently said that these fans were too noisy in his R3 – hopefully my fan controller will help there.
“Whiskers” wants to help…
I decided that the front drive bays must go. With advice from Ruthless I used an 1/8 (3.2mm) drill bit for the rivets, and it came out in less than a minute. I also cut a hole in the top 5.25 bay to help cable management for the front I/O and fan controller.
We had a discussion in another thread as to whether the 200mm Xigmatek fans would mount in the front of the Enforcer, but luckily in the big bag of screws that come with it, it contained just the right screws to mount it.
I used the rubber mounts for the top and rear fans.
Here is what I’ve got so far. Hopefully I’ll be transplanting my rig in there sometime this week. However I’m not going to be using the NH-D14…
Thanks for looking.
Thanks for looking.
