... to which I have fortunately also still come. Has been my first time with hardtubes. Fortunately, the Alphacool “Eiskoffer” was available to me. It really made my life easier at that point. Nevertheless, I have not only relied on it, but for example, for the measurement of the connection distances also resorted to other tools.
As you can see, I also built a better stand on casters to move the system comfortably and safely. Especially when installing the cables and hardware a big advantage.
The bending needs to be practiced. I'm definitely not a natural at it, and I've produced a fair amount of scrap.
One of my pipes has three bends, that's really hard to do.
I'm not completely satisfied with the result either. 1-2 more attempts and it would have been better, but I simply ran out of tube material. Now it stays like this for now.
At this point I must apologize for the brevity of my doc. Below you can see the functionally assembled, internally fully wired intermediate state, ready to be submerged and installed in the desk. Along the way, due to time constraints, I have now omitted many small steps and details, especially since I am still missing the photos. Because of my short time I concentrated completely on the completion. Currently something is still missing on the internal lighting, then I'll get all the detail photos including explanations.
The next step was then to fill it with water. This was a tricky one, with quite a few things going wrong. The following picture shows my filler neck. I discarded filling via the AGB, it's too hard to access.
So I dumped water in there and forgot that a plug was not screwed to the AGB. Was careless, the system overflowed and, due to the location, the water ran nicely from the overflowing AGB through the beautiful power supply. Certainly 200 ml. My mood you can imagine. At least there was no power on it. So I removed the power supply and put it in front of a fan heater for 2 days. As long as I continued with the old power supply. After the 2 days drying time I checked every single wire of the power supply, everything seemed to be ok.
With the AGB sealed, the filling actually went quite well. The problem from the first tests 2 years ago with air in the pump no longer occurs, but I had already put a vent hole in the pump head for emergencies. At the bottom of the Radis I have a ball valve for draining, which I opened (with the drain hose attached), then the system ran cleanly full. Run the pump briefly, refill, repeat 2-3 times, and the system was well filled with just under 2.5 liters.
Initially, the venting did not work so well. I had moved the inlet at the AGB to the top 2 years ago for deaeration reasons (bubble trap), so the water fell as a free stream into the AGB. This brought more bubbles into the system than out. Also caused a loud splashing sound. So I changed that back. I also put another stopcock in the hose underneath the filler neck. This allows me to prevent air from flowing back into the punch. With these two measures, the venting is quite simple and actually runs by itself. I can simply pull the two Radis from the holder during operation and shake them. Only in the hardtube after the filler neck (highest point in the system) is a bubble left behind. Spoiler: After 4 days of operation, however, it also disappeared.
Before the actual commissioning, I still had to finish rebuilding the desk. I exchanged the side panel for my own construction, whereby the new one is offset 10 cm to the inside. Then I carpentered a generous cable channel behind the cross bracing of the table. There is the master-slave-socket and the whole external cable tangle. And that's where the top opening of my side panel runs into. Likewise, the power connection from the base of the side panel does not run directly to the power supply of the PC, but via an intermediate plug to the master-slave socket, where my PC is then plugged in. This is how I preserve my beloved master-slave function.
I purposely didn't post an overall view now, I want to keep that from you guys until I finish the last lighting gimmicks. That won't take 2 more years ;-)
After wiring everything up, the big moment finally came: pressing the power button.
Everything dead, no reaction. Power supply broken? Feverish troubleshooting. After 10 minutes of checking various cables, I realized that my wife had pulled the plug out of the wall to charge her notebook. Plug in, and it runs! Without the slightest problems! What a relief...
The next steps I want to implement in the next few weeks are:
Fine tuning the Aquaero and the monitoring/controls.
soldering the LEDs for AGB and GPU
Manufacturing of the cover for the intermediate plate in the main room
Manufacturing of the bracket for the swiveling floor
With this, the PC is finished except for the fairing. This will take longer, but I'm already working on the exact manufacturing concept in CAD.
Hope you have not yet lost patience with me!
