Time to use the router again!
Got a problem while shaping the opening for the front panel. I could not reach the deeper areas with mounted guidance of the router. So I had to do them free handed. I don’t like the result but don’t know if I should risk damaging the main contour.
Front panel mounted, but backside front. Don’t want to get scratches on the grinding pattern.
Next step was to cut the panel for power and network cable. It too is made from 2 mm stainless steel, with a nice grinding pattern on it. The openings for the cable will be sanded and filled to look better.
