Scoob
Hi all,
I fitted some Samsung 2tb drives a couple of months back replacing the 1tb models.
These new HD204UI 2tb 5,400rpm drives are...well, pretty crap to be honest. Ok, they were cheap, high capacity etc. and the prior 1tb model was great. The BIG issue here is PAINFULLY slow write speeds - and issue that's reported many many times if you google.
My older 1tb Samsung drives (also 5,400rpm) work great, average read circa 80mB/s average write circa 70mB/s - a bit higher if I'm transfering larger media file like I often do.
The new 2tb drives on the other hand can hapily read at 120-130mB/s (fast) but the best I've seen on write is just 32mB/s! This is really really poor!
Now the cables / controller (motherboard) etc. are fine as I can pop one of the 1tb drives on the same channel using the same cable at it gets the expected GOOD write speeds. These new drives though get the same poor write speeds on ALL ports using ANY of my cables.
One thing I did notice, these new drives are supposed to be the new 4k block standard - however they announce themselves to windows as normal 512k blocks, so windows formats them as such. Not sure if this is right or not.
Still, they are formatted the same as the older 1tb models which work great.
Firmware is latest (though Samsung brightly chose NOT to increment the version number in their recent release) purely because of their manufacture date. I also installed all the latest Intel Rapid Storage drivers as suggested elsewhere but the drives are still rubbish.
So people, any ideas? I've never really had hard drive issues before of this type so I'm a bit lost.
Oh, while I remember, the drives are reported as only supporting UDMA-6 which is a bit crap, that's after installing the latest Intel Rapid Storage drivers. Before that (just using latest Intel chipset drivers) they were reported as supporting UDMA-7 but only connecting at UDMA-6.
FYI: my motherboard is an ASUS P5Q SE2 with the ACH10R controller. Drives are all in ACHI mode. There are NO BIOS updates available regarding this issue.
As JUST these new drives have the slow write issue and ALL other drives in the system are 100% fine there MUST be some issue with these drives. I mean, why would they have suck an unacceptably slow write speed?
Any thoughts / ideas welcome - these drives are in my media machine and dumping stuff to them is painful! I expect I'd have gone mad(er) already if I was transfering RAW video stuff to these drives!
Cheers,
Scoob.
Cheers,
Scoob.
