RV AntiFreeze Question
They say they "do not harm plastics (except acetate)". Quite often the plastic material on waterblocks are labelled as being acetal; I don't know if they're the same thing or not, but they sound similar. I'd look into that a bit if you have any acetal blocks.
Well I can't see any obvious reason why it wouldn't work, but maybe just wait to see if anyone has any actual experience using it as coolant before preceding with it :)
Is the only reason you want to use it the non-toxicity, or would it be a cheaper alternative too?
No, I'm not worried about the price. It's like $7.00 a gallon, and I do have an RV I can use the left over in.
Lol, remember, I am putting dual D5's in a CPU loop.
