reservoir mounting question
noudi93
hihi,
I want to ask wether or not it's safe enough to mount a reservoir with just 1 clamp.
the clamps are like the ones in this picture: (couldn't find a pic of the exact ones)
Cause there isn't really an option to mount the 2nd clamp
If you "not" going to kick your Rigg around the Floor, everything goes fine.
One Clamp is ok, maybe on the Top if possible and a little support from the Backside on the Bottom with a little Piece of Foam.
hmm ok,
Meanwhile i have found another option, but im not sure wether i like the looks of this. The res can still move now, but it's sturdy. It's just mounted to a piece of metal that has quite some flex to it, so the res automaticly has that flex aswell.
