Replacing cables by extentions or new corsair
GTX670
Hello, I have a question about replacing my cables, can I replace these ones ?
http://img208.images...04036tonybu.jpg
my PSU is the Silverstone Strider Gold Evolution 2.0 1000 WATTS
because I see cylinder hidden in the interior of the cables
could that be a regulator of amps or something else ?
I have no idea of what is it, it could be these cylinders that you see on some playstation 2 joysticks
http://www.tradenote.../1222590267.jpg
I completely have no idea of what I will do if I replace these cables by new ones and more esthetic like this ones : [media]http://www.youtube.com/watch?v=lFvJ5lagoCY&feature=g-u-u[/media]
Do you have you any idea of what it is ? Thank you.
i believe there capacitors just to help clean the power a bit more or they might be something to help with electrostatic discharge im not too sure also if your looking to replace the cables for your silverstone i dont think they do replacement cables for them so be prepared to learn how to sleeve and spend allot of time on them also dont buy cheap extensions or replacement cable on ebay or your pc will explode and everyone around you will die instantly in a huge nuclear explosion
those bumps in the harnesses. like my SS should be the +2 for the 6-pin to make 8-pin.
your PSU end should be 8-pin and all eight cavaties have wire in them. if only 6-wires
in the PSU end then they could be a choke of a sort, but don't think so.
airdeano
