Recent Build (7 year itch) unkown Issue
Kirk
Hi Guys
Rig Specs
Corsair Graphite 780T White Full Tower Case
Seasonic 1050W 80 Plus Platinum Power Supply + White Cable Mod Set.
ASUS X99 Deluxe
Intel Core i7 5930K
Fractal Kelvin S36 Cooler
ASUS GeForce GTX 980 Strix DirectCU II 4GB x 2 in SLI
Kingston HyperX Predator 16GB 3000MHz
Samsung 850 Pro Series 512GB SSD
Samsung 850 Evo Series 1TB SSD
I experiencing some issues with the new build and honestly have no idea what it is causing it.
Main issue is the pc after working perfectly after full shutdown when I try to switch it on sometimes will not power up unless I switch of the mains supply by the socket on the walls for a few minutes giving it enough time to be clear of any power that may be remaining in the pc then turn back on and power up then works fine, its very annoying!
I have tried clearing the cmos and reset everything to defaults doesn't fix the problem, I have remove the graphics cards and reinstalled them and also the same with the memory even pulled out the cpu and reinstalled.
On another note not sure if it would be related but if I enable the XMP profiles system seems stable then crashes randomly with random BSOD's, I though the XMP profiles would work without issues.
Well PC seems to be back to normal I have no idea why but fingers crossed the issue wont come back.
I have a quick question, I am considering adding another 16gb of the same ram but I believe that even if I purchase the same ram modules again they still may not work is this correct?
