Jgretty
I'm using http://www.corsair.com/en-us/domina...3200mhz-c16-memory-kit-cmd16gx4m4b3200c16-rog
and I'm getting way under the 3200MHz. cpuz says
Memory (RAM)
Total Size
32768 MB
I7 6850K, Asus Rampage V Edition 10, 32gb Corsair Dominator Platinum ROG edition 3200Mhz, MSI GTX 980Ti SLI, Samsung 950 Pro 512gb, Samsung 850 Pro 512gb, Corsair AX1200i, Be quiet! Dark Base Pro 900, Asus PG348Q, ROG Spatha
Type
Quad Channel (256 bit) DDR4-SDRAM
Frequency
1223.8 MHz - Ratio 1:18
Timings
16-18-18-36-2 (tCAS-tRC-tRP-tRAS-tCR)
Slot #1 Module
Corsair 4096 MB (DDR4-2137) - XMP 2.0 - P/N: CMD16GX4M4B3200C16
Slot #2 Module
Slot #3 Module
4096 MB (DDR4-2137)
Slot #4 Module
Slot #5 Module
Slot #6 Module
Slot #7 Module
Slot #8 Module
So am I to believe that my RAM is running at only 2137MHz? If so does anyone know why this might be?
Thanks,
Here are my full cpuz specs if it helps.
Processor (CPU)
CPU Name
Intel® Core™ i7-6850K CPU @ 3.60GHz
Threading
1 CPU - 6 Core - 12 Threads
Frequency
4181.23 MHz (41 * 101.98 MHz) - Uncore: 2855.5 MHz
Multiplier
Current: 41 / Min: 12 / Max: 42
Architecture
Broadwell-E/EP / M0-Step (14 nm)
Cpuid / Ext.
6.F.1 / 6.4F
IA Extensions
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3, TSX
Caches
L1D : 32 KB / L2 : 256 KB / L3 : 15360 KB
Caches Assoc.
L1D : 8-way / L2 : 8-way / L3 : 20-way
Microcode
Rev. 0x00000B00001C
TDP / Vcore
140 Watts / 1.321 Volts
Temperature
54 °C / 129 °F
Type
Retail (Stock Frequency : 3600 MHz)
Motherboard
Model
Asus RAMPAGE V EDITION 10
Socket
Socket 2011 LGA
North Bridge
Intel Broadwell-E rev 01
South Bridge
Intel X99 rev 05
BIOS
American Megatrends Inc. 1003 (09/13/2016)
Memory (RAM)
Total Size
32768 MB
Type
Frequency
Timings
Slot #1 Module
Slot #2 Module
Slot #3 Module
4096 MB (DDR4-2137)
Slot #4 Module
Slot #5 Module
Slot #6 Module
Slot #7 Module
Slot #8 Module
Graphic Card (GPU)
GPU #1 Type
NVIDIA GeForce GTX 980 Ti (GM200)
GPU #1 Brand
Micro-Star International Co. Lt
GPU #1 Specs
GM200-310 / Process: 28nm / Transistors: 8000M / Die Size: 601 mm² / TDP: 250W
GPU #1 Units
Shader Units: 2816 / Texture Units (TMU): 176 / Render Units (ROP): 96
GPU #1 VRAM
6144 MB GDDR5 384 bit
GPU #1 APIs
DirectX 12.0 / OpenGL 4.5 / OpenCL 1.2 / Vulkan 1.0
GPU #2 Type
GPU #2 Brand
GPU #2 Specs
GPU #2 Units
GPU #2 VRAM
GPU #2 APIs
Storage (HDD/SSD)
Model #1
Samsung SSD 950 PRO 512GB
Capacity #1
512 GB
Model #2
Samsung SSD 850 PRO 512GB
Capacity #2
512 GB
Display
Screen #1
ROG PG348Q (ACI3433)
Screen #1 Spec
34.2 inches (86.9 cm) / 3440 x 1440 pixels @ 30-100 Hz
Miscellaneous
Windows Version
Microsoft Windows 10 (10.0) Professional 64-bit
Windows Subver.
Build 14393
CPU-Z Version
1.78.1 (64 bit)
Memory (RAM)
Total Size
32768 MB
Type
Frequency
Timings
Slot #1 Module
Slot #2 Module
Slot #3 Module
4096 MB (DDR4-2137)
Slot #4 Module
Slot #5 Module
Slot #6 Module
Slot #7 Module
Slot #8 Module
Thanks,
Processor (CPU)
CPU Name
Threading
Frequency
Multiplier
Architecture
Cpuid / Ext.
6.F.1 / 6.4F
IA Extensions
Caches
Caches Assoc.
Microcode
Rev. 0x00000B00001C
TDP / Vcore
Temperature
54 °C / 129 °F
Type
Motherboard
Model
Socket
Socket 2011 LGA
North Bridge
South Bridge
Intel X99 rev 05
BIOS
Memory (RAM)
Total Size
32768 MB
Type
Frequency
Timings
Slot #1 Module
Slot #2 Module
Slot #3 Module
4096 MB (DDR4-2137)
Slot #4 Module
Slot #5 Module
Slot #6 Module
Slot #7 Module
Slot #8 Module
Graphic Card (GPU)
GPU #1 Type
GPU #1 Brand
GPU #1 Specs
GPU #1 Units
GPU #1 VRAM
GPU #1 APIs
GPU #2 Type
GPU #2 Brand
GPU #2 Specs
GPU #2 Units
GPU #2 VRAM
GPU #2 APIs
Storage (HDD/SSD)
Model #1
Capacity #1
512 GB
Model #2
Capacity #2
512 GB
Display
Screen #1
Screen #1 Spec
Miscellaneous
Windows Version
Windows Subver.
Build 14393
CPU-Z Version
1.78.1 (64 bit)
