Hi folks,
I've got a core 2 quad extreme, QX6850. I'm currently running it at 3.33 GHZ stable although it get's really hot. 90 degrees almost according to core temp.
I've ordered a Noctua nh-d14 which should arrive next week sometime which will hopefully bring my temps down a bit, but I was wondering, what's the absolute best I can hope to get out of the QX6850? Has anyone here had any success with getting it to the 4GHZ mark?
Also, I want to add that I don't believe my temp readings that I get from core temp. Using everest or Aida 64 I get readings more than 10 degrees cooler. Also, when I quit prime 95 I see the temperature drop 20 degrees or so within a couple of seconds which seems impossible to me which is why I don't believe the readings are accurate.
Here is picture of my readings idle.
Full load after about 10 minutes:
Like I said before, when I exit prime 95 it will lterally drop 20 degrees in less than 2 seconds.
So I really have 2 questions here. First of all, which temp reading should I believe? And secondly, how much more could I get out of it with the Noctua?
Many thanks in advance for any advice.
