Project Xelladesk (Computer Desk Build)
If you're going to be working with wood, it might be worth investing in a router. It'd make some jobs so simple.
http://www.screwfix....ter-230v/41123#
I have access to a range of tools for woodworking through a friend but thanks for the tip.
I'd say Beech is the best there, if tulip is too light for you.
Yes I think I will use beech, also found a local wood shop where I can look at the wood before I buy so will be going there at some point in the next week.
Thanks for all your comments!
