[before i start with the wrighting, i don't think i'm breaking the project rules, but if i'am then sorry, i'll have some proper work photos tommorow]
Hello all. :toast:
This project is going to be a fully custom semi-cube (namely basically cubic, but not exactly :naughty: ). Its going to be made, as the name suggest, out of mainly Wood and Metal, with Water being used for cooling. The Plan is to have all of the insides built from metal to aid cooling, and then having a 'second skin' of 12mm mahogony around the outside to give the correct looks. The metal parts will all be bolted together, while I havn't decided hot to get all the wood together. Also, all the wood is going to be professionally milled on a Boxford CNC Wood Machine.
So, lets start then shall we...
The Front Design
(all CAD done on iMac using Cobalt)
Thats how the front started out a few days ago. Now, after an afternoon of CAD we have....
The Materials
For the wood, I'm planning on using pale Mahoganny, 5mm for the front plate, and 12 for the side panels ect. As for the metal, i'm using 3mm sheet, and 3mm right angle bars for rigidity. All of this should be cut by tommorow after-noon, so i can get tapping. ohh what fun.
The Hardware
For the actuall parts, there are only 4 things i'm sure of, and they are an Aquacomputer Aquatube in silver, a Black ICE GT Stealth 120.2, a Samsung DVD-RW and an Aquero USB in blue.
The Timescale
I want to get all of the panels ect. machined by the 30th of June, so i can spend the rest of the summer putting it together ect.
Next Update
As i've said before, i'm hoping to update again tommorow with a fully done front panel and the various bits of metal having been cut.
Thanks.
AJ.
			Hello all. :toast:
The Front Design
The Materials
The Hardware
The Timescale
Next Update
Thanks.
AJ.
