Update
This mod/build is made possible by
So here is a small update.
So all the panels are sawed in their rectangular pieces, now I only need to kut the right holes and the fan cut out in some panels. Some holes are done, not all, didn't have the time today, because of editing video's.
all the panels, (also leftovers from the sawing) one panel from caseking is unused, but it's for safety, you never know if something gets broken.
(Left top corner are the res panels)
This is the hole for the powerbutton, the rest is a mystery.... (you can guess what that panel is for and what i'm going to do with it)
Because of the bars in the right corner (forgot to remove them) the mid plate of the 800D isn't totally flush, so I'm using the dark red acrylic for raising everything up so the res can sit flush on top of the dark red panels. The uv red acrylic is the bottom of the cage for the ssd's and the pump. And I'm probably going to try mounting the NZXT Pcb's in there too.
Sun is shining.
I also removed the black sleeving from the NZXT led kits and sleeved them in there led colours. So red sleeving is the red led strip and white is the white led strip
You can see a little bit of wiring, but since the wires are red and black, it perfectly fits the colours of the case.
The pci brackets are also painted, but they are still drying, so I didn't yet make a picture.
So that's it for this update, gotta find some glue now, see you the next one!
