Are you going to make all the tubings that way. I looks just epic![]()
Looking good man. Oh by the way, push fit fittings are much safer than compression fittings, I have never trusted and will never trust compression fittings. The only true compression fittings that work are ones that use olives that crush after use, so you can't use them again. Push fit FTW! What size pipe is that 10mm? Also, where did you get the push fit from? I'm looking for 13mm push fit, but I can't get them in 1/4" only 1/2".
