looz
Active member
Sadly got no photos to share for this starter post, but making one so I won't skip documenting my project.
I've had a bit of a storage problem lately and finally pulled the trigger on shared storage.
I've got some hardware laying around from older PCs, so going to take advantage of them and ordered some filler parts to get a whole NAS.
Currently I've got the following:
Ordered, hopefully arriving for next weekend:
Plan:
FreeNAS as OS, with two zpools. 3*500GB SSD in RAID-Z1 for flash storage. HDDs in "RAID10" arrangement for mass storage, aka. two VDEVs, each with two drives which are mirrored forming the second zpool.
OS drive will be the Samsung nVME, which will also host VMs and jails, whichever is feasible for the software intended. Lancache requires linux so that will run inside a VM and also use the SSD pool.
Since the setup will be used over 1Gb NIC at least initially, no need for fast cache drive. 32Gb ram should make it snappy regardless for everyday use. And yeah, silent corruption is a possibility with non-corrected memory, but whatever. At least it will be on top of UPS which can initiate a controlled shutdown in case of power outage - so complete data loss should be relatively unlikely.
This is a subject to change, I might go LVM on top of linux software raid, but let's see how it pans out.
- Random laptop HDDs (probably not using)
- 4Tb hard drive (probably using, but has some data that needs backing up first)
- Samsung EVO 970 500GB
- Z370-F Gaming
- Antec 300 "flavour town edition" (more on that later, lol)
- 3* 4Tb Toshiba P300 drives (Not optimal because SMR, but I'll make do - were cheap)
- 3* 500GB MX500 (50€ a pop on Amazon, maximum order)
- Pentium G5420 (Cheapest non-Celeron compatible CPU - also ECC compatible if I come to my senses later)
- 2*16Gb Non-ECC 2666MHz memory
- Eaton 5S 550i UPS
- Cooler Master MWE White V2 400W
Plan:
