Project P182 Watercooled V2!
I know I've not updated this in ages, and it's because I've not worked on it in ages. I got it to this stage and kinda lost motivation:
I've been promised a GT300, so in the back of my mind I'm not wanting to get watercooling set up till I've got that card and wont have to mess about swapping it out a month down the line. And tbh, I use my macbook for most of my general surfing so there's been no motivation to get it up and running in any reasonable timescale :lol: .
I've got a week holiday from work in two weeks time (although am going to visit a friend all the way up in dundee for a big part of it), so maybe I'll get a little bit of work done on it then.
Dan
GTX 480 Has Arrived!!!
So, after what must nearly be a year of not really doing much (besides running this rig on air), I've finally done some more work on this mod.
Here's the reason why:
:D
Will fill you all in tomorrow, when I've had chance to edit the pictures and write up some witty comments :)
Dan
I'd given up painting the NF-P12's because of how awkward it was to do with the fans still attached, I'd heard they didn't come apart like regular fans so hadn't tried it. Though after watching that video I might attempt to do it at some point. So thanks siravarice :)
I didn't get chance to edit the pictures yet (hence there not being a post yet :P), but stay tuned for an awesome update tonight :D
Dan
The End Is Near :D
So we all know how hot and loud the GTX480 is, so something had to be done about that.
I wonder what will happen if I take this off.
Hmm, there's still more junk that's not needed under here.
Off that goes too.
That's more like it.
You should have seen how much thermal paste was thrown on the GTX480 heatsink, you could probably drop the temperatures of the GTX480 10 degrees by re-applying the thermal paste properly!
So, that's everything loud taken off the GTX480, it should be pretty quiet now. Let's see what I've got laying around to sort out keeping the card cool.
This white box looks promising.
Who can guess what's in it?
Ooh, a shiny thing! How shiny? This shiny:
(and here's a shot of the underneath for all the people who like shiny things too :P)
Those two holes on the front side (pictured above) are for sticking LEDs into, I think that'd look pretty magic lit up inside the case, so will have to look into getting those lit up at some point in the (hopefully) near future.
And there's the waterblock installed :D
Dan
Finally Finished!
So I'm afraid I was so eager to finally finish this rig, that I didn't take anything else in the way of assembly shots, but I hope the final product shots will make up for that :)
I took that long to get watercooling up and running that swiftech brought out a new CPU block in the mean time. So this is just the Apogee GTZ, else I'd probably be running whatever the new one is.
Spot the GTX480!
If you're wondering what the extra metal things sported in the middle of my tubing, they're Koolance Quick Disconnects, so that I'll be able to remove either the GPU or CPU without having to drain the entire loop and faff about with un-barbing parts of the tubing.
I'm rather pleased with how clean I managed to run the cables here. The pipe on the left is the return pipe from the CPU/GPU loop, and it has the T-Line filport on the top. While the pipe on the right is the flow towards the CPU/GPU loop, straight from the radiator.
I was just sat looking at this picture wondering why I decided to cross the inlet/outlet over on the radiator, and then realized it was so I could make smoother bends that were less likely to kink.
That on the bottom left is a T-Balancer BigNG fan controller thing. It's pretty awesome actually, and there is no end of customization you can set on the fan profiles and temperature sensors. I modified the power connector on the Laing DDC Ultra to use a 3pin header, so I can use the fan controller to power the pump speed as I see fit. :D
I'm running a Patriot Torqx 128GB SSD for boot, and a Samsung F3 500GB for storage. They're suspended using elastic, so any of the HDD's vibrations wont get passed through to the case (which amplifies the sound). I know SSDs don't vibrate, but I was going for a uniform look with suspending that one too :P
(Click for a very large view)
And that's how she looks. :cool:
And the outside. With some internal lighting, you'll be able to see through the tinted perspex which should look pretty sweet.
You can probably see that the outside of the panel is kind of distressed. Not to the point where it's obvious looking at it in normal lighting, but enough that I'm kind of miffed with it. The distressing happened when I had to separate the aluminium from the plastic inside of the case to cut the window hole out. It was stuck on pretty good and the aluminium kept bending as I tried to ease it off, hence the distress marks. I've considered trying again with a new panel, but I can't think of a way to get it off cleanly or find a clean way to cut the inside plastic hole larger than the outside aluminium hole. So I'm going to leave it for now.
I like to think that even my cable runs are tidy :D
So that's my mod pretty much complete. And it only took me just over a year!
I blame Fermi's delay for my lack of reason to get it ready quickly.
Hope you enjoyed reading it.
Dan
PS. I'll probably still post a couple more updates at some point if I ever get round to spray painting the Noctua's and lighting the inside up like it deserves! But with how long it took me to get to this point, don't hold your breath :P
Thanks guys :D
I've edited my post above to add a high res picture link to the main overview of the inside of my case, which you can view here.
Temps aren't the best I've seen for GTX480 waterblocks, but I've not really seen any definitive reviews of the competing blocks so I could be wrong.
I ran furmark @1920x1200 and got 59oC load, and 32oC idle. My room was about 23oC.
Yesterday though I ran furmark and got 77oC and 38oC(!), so I think that there must have been some air stuck in the block or something. The pump had stopped bubbling, so I thought it had finished bleeding, but apparently it hadn't completely bled the system yet.
But I'm definitely pleased with the results compared to the stock cooler, which hit 95oC on load and idled around 54oC.
Dan
I looked long and hard at gtx 480 but in the end I decided to jump to the red team for a while to see if rev 2 fermis are much different.
Im a bit of an nvidia fan boy tbh, Ive come from bfg gtx 295's on water (quad)
Ive got to say however, these 5870's are damn fine cards in xfire with EK blocks.
but ofc you sir have the edge on hardware tesselation !!
anyway great build bloody fine work m8
Rick
I always felt kind of guilty about getting this project to 90% of it's potential and then settling at a stage where it just worked.
While I'm still happy with the hardware in my PC, I've decided to give this project a lot of love, and finish off that last 10% of cosmetic touches.
Starting with getting rid of the awful tan colour on the Noctua fans (sorry Noctua, you've got nice fans, but a horrible sense of colour!), replacing my tubing with something a little more customised (a secret to follow), and upgrading my CPU waterblock while I've got the loop apart.
Anyway, these arrived today:
Watch this space ;)
