ciobanulx
Hey guys,
I have some more fittings to show, this time some extensions. Thanks a lot to Hugh from mydiy.com.au for helping out with these Barrow fittings. You can check out his eBay store HERE with some good prices on fittings.
Not sure if I will use all of them yet but they will definitely come in handy for all the small tight corners in this build. I also need some spots to be really strong so just tubing won't do. Will make sure to show once ready.
Thanks for checking it out.
Cheers,
Alex
