I use it often. I suggest buying the 90degrere blades for longer length pieces. Also it is perfect for hobby wood 18mm thick. i did a practise piece and managed to cut out the razer logo quite well on thin acryclic.
The only thing I dont like is the guide piece that they provide, its supposed to help cut straight, but there is too much play/wobble on it so you cant trust it.
Also I DONT recommend cutting thick pieces of metal. None of the blades I had could take it and snappedI suppose its possible but you have to go extremely slow.
edit* Sorry for thread jacking.
Awesome rig setup so far. I love the skull on the mem blocks. thats pretty impressive. I have my Cameo on order so hopefully it comes soon.
Skull decals look good! You should sand down the GB logo on the mobo heat sink and put a skull on there too.
Whilst I truly believe that water cooling ram is the crappest of the crap I must say I do like the skulls. A lot.
ARRRRRGGGGG![]()
Once again Alex nice work, I do like the way you work and how clean the case looks.
Nice very nice.
This rig gets better with every update dude!
That front panel!![]()
Thanks a lot guys
Glad you like it. Hope to start on some tubing and cable routing soon. Still waiting on fittings and cables to arrive![]()
Can't wait to see the next updates![]()
I cant wait to see the temps on this! Great fun build!
I just woke up and that top picture basically looked like a video card to me for a split second and now I'm convinced someone needs to make a video card like that.
Does look really nice mate!
This build keeps getting betterThose fan grills looks amazing with those rads, well thought out. Keep em coming.
Loving the Corsair logo!
