Hey guys,
Here are some more progress shots!
I did some similar vinyl work as on the rads, on the pump and also added a patch of vinyl to the bottom of the case just to give it some more contrast. The rest will be covered by the rads and motherboard tray.
Have a look and sorry for the dark shots, this was just after I did it. I will have better pics of this soon.
There is also a package of watercooling goodies that arrived from PerformancePCs! It's stuff like this that PerformancePCs are good at, I think they stock the largest amount of watercooling and modding gear in the world and they have every possible little thing you might need.
If you haven't already, it's really worth checking them out! They have international shipping with Fedex or DHL which arrives withing 3 to 4 business days and if you make a large enough order the shipping fee is pretty decent.
Have a look what I got for this order, mainly small things I couldn't find anywhere else in Australia.
All the fans and lights will be connected to this PCB to help with cable management.
Different pump top for the DDC pump and the Bitspower upgrade kit with the res.
Also got the multi port top and an aquapipe to return the loop to the top of the res.
And this is something I've wanted to get for a while. The Phobya external power supply.
It's really good for outside testing of fans, lights and even running a pump test or something, good and handy to have.
Simple molex connector and you can just connect a small PCB with different connectors to that.
That's it for this update guys!
Stay tuned for more!
Cheers,
Alex
