Project: Kitsch Box
Looks like it should improve flow a lot, just out or curiosity was the res full or was there air in it?
I can't wait to see the res lit up. :)
Don't be silly, course there was water in it. The pump was working & there was flow, it just was'nt getting as much water as it needed.
I'm still thinkin how to make up the LED plug. Might have to get a short length of clear perspex bar, thread it with a 1/2" die & turn it to shape on a lathe. Bit expensive for just a plug though, with the 1/2" die costing me £15 alone.
Maybe you could get a brass plug and drill it out and epoxy and LED/s into it, it might not look quite as good but it maybe cheaper. What color are you thinking of?
Sounds like a good idea. I've got a 1/2" to 1/4" thread brass reducer here, that with a bit of modding & shortening might be good to use with a coolplex plug.
The coolant i'll be using is Zalman's ZM-G100. It's blue so i'll probably just use a white led to illuminate it. With the coolplex plugs the led's are push-in so they're simple enough to swap out.
On the subject of lighting I will need to come up with an effective but subtle way of adding light to the case. I think cathodes would be too big & overpowering. Maybe a few strategically placed led's would be better, but i'm jumping the gun here a bit.
name='Rik-Sik' said:
looks mental ! alot of time and effort has been put into this and it should pay off! keep it up man lol
I dont think you saw the date on this thread, its OLD! rofl, i bet llwyds cursing me now, I remember your rule and meh, ha ha ha ha, (or was it not you and im imagining things?!?!!? XD)
