UPDATE 02/08 - Unboxing & Overview of GIGABYTE GTX 780 OC
This is truly some amazing work you're doing here! Can't wait to see more!
Thanks a lot, appreciate it!
Here's an update! Let me hear what you think about it all! Both the presentation/video and the product itself
UPDATE!
Unboxing & Overview of the GIGABYTE GTX 780 OC - 02/08 -2013
UPDATE 02/08 - 2013
Hi there!
As you may have found out from the topic of this update is that
GIGABYTE have supplied me with another great product.
This product will really give this project that big extra touch, namely nothing less than a -
GTX 780 OC (GV-N780OC-3GD) graphics card!
I'm very thankful and happy to have gotten the opportunity to feature this amazing GPU in my project and build and I think it will raise the awesome-factor even more!
So this update will be about the
unboxing and an overview of the GPU that will take place in
Big Bro' Prodigy. So for the moment what I'm pushing inside my poor (but lucky) Prodigy is an
E-ATX motherboard (Z77X-UP7), a
GTX 780, custom water loop with
2x 240rads + 25cm reservoir and more! Talk about compact
I have made an
unboxing and overview video that I would ask you to check out (thank you in advance!
I'm trying to create my own and new style in this video so please let me know what you think! Example the texts sliding in and such stuff.
I will however also put up pictures and additional text to support the pictures.
So let's go!
______________________________________________________________
Here's the unboxing and overview video uploaded on YouTube:
http://www.youtube.com/watch?v=0INkyhlWRxw
Pictures and additional text:
Here's the box of the GIGABYTE GTX 780.
The content of the box:
- GIGABYTE GTX 780
- 2x Molex to PCI adapters (6- and 8-pin) - in case you lack the cables from your power supply.
- DVD with softwares (Drivers, OC GURU II etc.etc.)
- Quick Quide - Useful if you are unsure how to install a graphics card.
Here's the beauty, the GTX 780 with the Windforce 3X 450W cooler. It performs
as good as a GTX Titan but comes much cheaper, being a lot more "bang of the buck".
Example: In Sweden the GIGABYTE GTX 780 is 25% cheaper than the chepeast GTX Titan.
Dimensions of the card:
- L = 292mm
- W = 129mm
- H = 43mm
The height of only 2x PCI-E slots enables SLI-configs
Since this is a factory overclocked graphics card the clock frequencies are higher than the regular GTX 780. It performs more or less
like a GTX Titan thanks to the OC.
- Core: 954Mhz - 11%~ higher than stock core.
- Boost: 1006Mhz - 12% higher than stock boost.
The brand new Windforce 3X 450W cooling solution consists of:
- "Triangle Cool" Technology (please check the video where I explain it @06:03)
- 3x Ultra quiet fans - Quiet even under heavy load (yes I've tried it out myself!
- Two massive heatsinks
- 6 copper heatpipes - 2x 8mm & 4x 6mm
- Able to dissipate 450W of heat.
Two nice things on the back of the graphics card.
- "Anti-bend" mounting, a metal piece preventing the PCB from bending due to a heavy cooler. Not bad! (makes me feel safe
- Black PCB! Finally black PCB on GIGABYTE cards, awesome for the color scheme - black goes with everything.
Video outputs:
- Displayport
- HDMI
- Dual-link DVI-D
- Dual-link DVI-I
Four screens can be run on the same time on a single GPU! Also of course 120Hz screens and such.
Driven by two connectors. 6- & 8-pin.
Additional photos:
And finally up and running!
Please do take a look at the video I've posted as I would appreciate that a lot! Also I explain it all better and in more detail than with the pictures and text - the photos and texts are complementary for the video in case you don't have the possibility to watch it.
So this graphics card beast will be in this project, how awesome isn't that?! I look forward to try it out and do some benchmarks, try the cooling solution out, overclock the card and stuff a like!
Anything specific you're wondering about let me know and I'll try to answer it!
I’d love to hear what you think about the video and what you think of the GTX 780 inside of the Big Bro' Prodigy!
Thanks in advance,
Best Regards
Nikkop
