Hey folks,
It was some time ago since I posted last, looking at 3 years ago last month, it's good to be back.
My previous project was interesting and very budget orientated given that I was mid way through uni at the time, that time has now passed and budget almost isn't remotely important.
My previous build was a scratch build, this new build is going to be within the amazing NZXT H440. Although this case is a good couple of years old, it'll still be amazing even for the next year or so.
AE90 is the name of this project because the loop will consist Almost Entirely of 90 degree fittings. I couldn't think of anything else creative enough.
There is some history to this, that starts on my previous build log (see signature) I typed this all up and kinda realised it was only a massive wall of text, so that got deleted.
At present, I am accompanied with various new bits of kit, I got my hands on a 1080TI FE from Palit, after buying this, I was able to set the record for the fastest i5 6600K on the 3D Mark 11 Extreme benchmark for single card users and this was featured on the Hall of Fame position 54, then Ryzen happened. However I am still the fastest featuring the i5, with a score of 13328X, with a core clock of 4731 MHz, and the GPU at 1759MHz. I have yet to delid the 6600K so that will be attempted at some point.
Also most recently featuring here is the 7700K and the Asus Maximus IX Formula. The whole system is as follows.
Case: NZXT H440 Matte Black 2015 Edition (previously has Red/Matte Black)
CPU: i7 7700K (previously i5 6600k)
Mobo: Asus Maximus IX Formula (previously Hero VIII)
RAM: G.Skill Trident Z Red 3200MHz
GPU: Palit 1080TI FE (previously Asus 290X Matrix non-plat)
PSU: EVGA SuperNova 650W P2 (previously G1 1000W incase I went crossfire with the 290x I previously had)
M.2: Samsung 950 Pro 256GB NVME
SSD: 2x HyperX Fury 240GB
HDD: WD Blue 6TB
Watercooling:
Rads: 2X EKWB CoolStream SE 360
Res: Singularity Computers Protium Medium Res Tube
Res: Singularity Computers Protium D5 Top in Clear Acrylic
Res: Singularity Computers Protium D5 Cover in Silver with Silver rings. (So proud to have those three things, although I actually ordered the black with silver rings, and got silver with silver rings?!?).
Res: 2x Singularity Computers Ethereal Single Res Mounts in Silver.
Pump: Whatever the F*$k pump EKWB puts in their res+pump combos
Waterblocks: EKWB Supremacy EVO Nickel Plated, 1080TI FE Nickel Plated Block with Nickel Plated Backplate.
At the moment this system is running, and I am using it to type up this thread, so most photos will consist of the build running, photos would be of things having changed, such as new cables for example, etc. On the other hand, there are various things to be done, not limited too:
1)Hardline tubing,
2)new sleeved cables, might get cablemod to do me some custom ones, given that I have a code for it.
3)Case mods,
a) removing the hard drive cage/panel thing,
b) extending the window,
There are other things I intend to do as well, however I like the element of surprise, so I will say no more on these.
One thing I will say is I intend most of this build to have very neutral colours, the reason for this is so all I would need to do to change the colour scheme, would be to change coolant and change the RGB lights on the board (and/or elsewhere). So I will allow yourselves to decide, what colour scheme should I do?
See photos below.
Above is the build in general, currently running standard tube at the moment, because it is quick and easy, mind you the bend from the radiator to the cpu block I am concerned about, so the necessary hardline fittings for this are currently in my possession and I'm going to sort this part out as a matter of urgency. Not to mention these current fittings are compression fittings with tube from EK that is meant to fit, but doesn't.
Another angle, you can see why I am concerned about that bend, also hence the kitchen roll.
Obviously the 1080ti block, the newest FE edition.
This is it outside of the system, some fair weeks ago now.
The backplate is literally amazing.
Forgive my poor cable management and lack of sleeving, that is the power for the pump, not so sure why I choose that route.
SSDs
Cablemod Blood RED cables, these will likely be replaced.
Because who doesn't like the additions they put in motherboard boxes these days.
This is my current setup, 1080ti box far left, with the formula XI box their too, WC gear to the right, past and present (also other peoples things, i.e the ryzen box). This is literally the best game of Tetris
That is me signing off for now, next update certainly this week, or even today.
HDD: WD Blue 6TB
Watercooling:
1)Hardline tubing,
3)Case mods,
See photos below.
SSDs
