Phanteks PH-TC14PE + Z77 Sabertooth?
MushroomBomb
First I'd like to say hi, been following the forum for a while but and decided to finally register!
On to my question, basically does anyone know if the Phanteks PH-TC14PE (White) will fit with my Asus Z77 Sabertooth? I've searched for answers via Google but couldn't find anything really. The closest I got was a test bench spec with Sabertooth and the Phantek, so based on that it should fit.
Second part of my question isn't as important but just curious what you guys think will look the best in my rig if I do go with the Phanteks PH-TC14PE. I had my eyes on the White/Silver version as it seemed to fit my overall color theme (White/Black) but then I saw the new Phanteks PH-TC14PE Black Version and thought it looked really sleek so yeah based my other parts what do you think?
CPU: i5-3570k (already purchased)
Motherboard: ASUS Z77 Sabertooth (already purchased)
CPUHS: Phanteks PH-TC14PE (white/silver or Black)
RAM: Corsair Vengeance 8GB White LV LP (already purchased)
GPU: To be decided, probably a GTX670 or 660
HDD: WD Black 750GB (already purhased)
SSD: Crucial m4 128GB (already purhased)
PSU: SeaSonic M12II 620 (already purhased)
CASE: Corsair 500R? Corsair Obsidian Series 550D? haven't decided yet, the silent option with 550D is appealing to me but I love the White/black with the 500R.
it should fit. likein Tom's review http://youtu.be/mR1kmhirI7Y (about 12min into the video)
your RAM choice should have no issue, but if it does, you can adjust the outer fan for
clearance. you wont be able to move the fan if need be to the last location due to the
VRM shield on the sabertooth.
its the case that is close. itll be close, oh so close.
watch the vidoe two of three times to be clear on what is in your future..
airdeano
Yeah I've watched that video already. I'm not concerned about fitting it with my RAM choice since it's Low Profile but the armor on the Sabertooth has me "worried". I imagine it will fit but it looks like it might be really tight.
Well I finished my build so i can confirm the Phanteks fit with the Z77 Sabertooth. Was a little rough getting the final clip/screws screwed in but it's done!
