What about the option of a newer model Caselabs? You can still do some basic modding to parts but still have a great case. You could do multiple powder coats etc.
Just a thought and any case you use will most likely turn out good. I'd honestly stand them all your selections side by side, pictures work for that, and the first one to catch your eye...
The advantage to a Caselabs case is the super high build quality means the case can last through 4 or 5 builds and still be awesome. Plus if when you mod you screw up you can order a replacement part easily.
Orca hasnt changed since she was built at all. Ill mothball her when shes retired though, maybe a strip down clean and service but then graceful retirement.
Its difficult to find the time to keep making changes to a personal rig when I have all the work stuff to do!
