Okay, continuïng in this post because this post wil have a lot of "build" int it
First off, i am really terrible with ordering complete orders, so i frequently stumble on the fact i miss some parts...
In the big order (with the cpu block etc) i made one mistake, i thought i ordered pairs of fittings, but they were singles (so i was 3 short to build something).
I knew i wanted to go acrylic and that i needed more fittings so that would be fixed in the next order.....which i got in the mean time
I also had an order at another company, for a NB cooler, and some other small stuff, which i also received
Today i ordered some small stuff for a fillport, and a very nice suitcase filled with acrilic bending tools
Probably will get those next monday, so then i can get really building
Now off to the build.....
I made myself a nice looking (i think) drain....the y piece is rotary, so i can even rotate it a bit down
other view
Let's show a problem....haha....i am gonna fix it by placing a extender under 1 of the fittings......this is the NB cooler btw, and i expected the acrylic fitting to fit without the extender, sometimes i make judgement errors
Now off to the cpu block, i needed to replace the mounting system, standard is intel and i needed the amd, so let's begin
First i got myself a piece of foam to work on (to not scratch anything), i peeled up the protective "sticker" and placed the block and mounting system in the orientation the should come
just unscrew the screws, dont touch the plating on the block and work tidy!
When it was open i couldn't resist! so much shining bling.....awesome!
Overall picture, when i first placed the mounting plate it didn't click (as mentioned in the manual), i had it upside-down, turned it up and clicked right in! Don't lose/break the rubber gasket it needs to be replaced
The rubber gasket is a little prebend so if you line it up you can just carres it in with a fingertip, make sure it fits nice and snug!
Placed the coolblock back on the mounting plate, then tighten the screws in a crospattern......
Endresult!
Oh no, there was a little wite speck one the middle O of the O in "OUT" but when further investigating it was just left over sticker
made the picture because i first thought it looked ugly (misproduction or something) but when i understood it was the sticker i thought it would be handy for other people
Fisnished up with some nice fittings!
So what's next....of course getting the motherboard and cpu out and replacing the cpu cooler
, fun, fun, fun, or is it?
got my motherboard out quick and of course made a picture
I don't know if it's the correct way, but it's my own selfthought way.....there is a little pin which locks your cpu in your motherboar socket, i unlock that pin so i can remove the cpu and the cpu-cooler attached to eachother, as the picture is taken you push it down and to the right (on this motherboard)
But offcourse then you end up with this, which can be hard to separate (in my case almost impossible.....i had a fairly hot and overclocked setup the last 1,5-2 years, which i think "cooked" the two together)
Off course i tried turning and twisting it off, bot no move whatsover.....so what did i do (after trying al kind of reasonable stuff for about half an hour), i got a little screwdriver and wedged it (gently) between the coolfins of the coolblock and the green pcb stuff.....
I saw the silicon about getting ripped of the pcb so i stopped, thinking i am f#cked...but then i saw the cpu was moved maybe half a mm, so there was progress!!!
I continued gently on the other side using the screwdriver as a lever and after doing that to all sides it popped off! Yeahh, or maybe not because it fell like a meter high and crashed on my hard floor.....shit been here and last time it didn't end well....
Let's look how many pins are bend, oops that's a lot and far too! i don't have any good pictures because the camera on the iphone just can't see it (i have problems with that too), but here was one picture with when i was almost finished....
I used the little iron wire to get under pins which were bent almost flat, then pulled up the wire a bit, and te pin would rise a bit, i used the smallest philipshead i could find, which ended up being about the same thickness as the spacing of the pins on the cpu is, so i had (lucky me) a tool to space the pins back (90% good)
I imagined if i could bend them straight enough, it will work because of the locking mechanism of the socket (it will staighten them back, but they all need to go in there own pinhole!) btw i did use a little magnifier, for example on the picture you can see 2-4 pins not proper, somewhere in the middle, i found the because it wouldn't fit in the socket, but i thought i had them al, someway the 2-4 pins there were bent too, after fixing that it's just hoping you fixed it right....
So happy it fit eventually (longest cpu change ever for me, for a total of 2 hours)
So continuïng with the waterblock, because there is only one more way to find out if i broke my cpu.......
preparation is always good, i need the washers and the springs, the jetplates i left untouched
The stuff i needed for the mounting of the backplate..... 4 off the standoffs (thumbscrew-things) were for intel 2011, so i didn't needed those
It's a shame i didn't make picture of the backplate, but it's just insulation with a silver metal backplate....but now it feels like i forgot something....sorry for that!
I placed the backplate and insulation, placed the washers on my motherboard, and screwed in the standoffs
Damn it does like nice when fitted! (off course i tightened the thumbscrews in a crosspattern)
Ohhh seems i did made one of the back(plate) too.......
I really wanted to test it and forgot to make some pictures, but here's a picture of the leaktesting (i know the tube is bend, from rad to cpu, but i couldn't get it to fit, monday i will fix this beacuse then i can go acryilic, also a reason why i didn't fill up the system, it's full enough for a week)
I had no leaks btw, only some fill spills (if that is even english
For the people who think, damn he is crapping on in that old crap, where's the new design?
It will follow and the next post or so, but for better readability and reference (quoting) i decided to split this and that post (to keep the old build a bit separated from the new build) (that post will follow prob tomorrow, because tonight i am going to play some darts, and that too will gonna be a long one
I did wanted to post, because i feel i have so much to post about the last month, but for now this will be enough for me
Thanks for reading and everything else!
