Older AMD Athlon overclocking....
winX
Since this looks like forum for ppl with newer CPU's.... any tips for older boards and cpu's???? ant old threads and/or links?
Athlon XP's??
What type is your processor and mainboard? Some more info would be helpful so that we can help you OC :D
http://www.sysxtreme.com/member.php?u=521
Athlon 1.2ghz - Whats that a K6? I forget now..
You may get a marginal overclock from the chip by increasing the FSB in your motherboards BIOS - but i doubt the board will have any kind of bus locking features, which will mean you will only be able to achieve a slight overclock from it.
If you do have the option to increase the FSB (Front Side Bus) speed in your BIOS, put it up 1mhz at a time and each time ensure you can boot into windows.
Once you have found a speed that does not allow you to go into windows, go back a couple of mhz and then perform some stress testing (like playing games) to see if your machine crashes.
No, XMS!!!
Athlon Thunderbird!! The pwnage of all processors.
Be careful, those things run very warm...winX
What kind of CPU cooling you have?
