name='Eguy' said:I stay strong on my recommendations, if you like wireless get the G7, wired G5Razer can go suck the **** they have been already
name='FragTek' said:Performance-wise I don't think you would even been able to notice the slightest difference between the Razer and G5/G7.
? Nope, the Copperhead, the G5 and the G7 are all laser, using the same agilent sensor although afaik the G7 uses the v2.Kempez said:The G5's are Lazer mice and the Razor is 1600DPI optical
name='Phnom_Penh' said:? Nope, the Copperhead, the G5 and the G7 are all laser, using the same agilent sensor although afaik the G7 uses the v2.
name='Kempez' said:Was talking about my mouse and the diamondback that was actually being discussed. I fancy having the G5 as this razor is feeling too small for my hand![]()
NickS said:
NickS said:I don't use the drivers for either my logi keyboard or mouse.
On the Keyboard, the Internet, and Email buttons along with WMP and volume controls work without drivers. On the mouse the back and forward buttons work without drivers, so do the cruise buttons... so i don't bother. Sidescroll is buggy, plus with the Logi drivers I can't use my side buttons in CS... yet I rly dont use them anymore. I use the numbers to switch weapons now.
Nick
Raven said:disagree with you there.
first off all they dont support my mouse in xp64 which would be a very simple thing with setpoint and they have no plan to support it.
and their drivers are so incredibly bad you cant even imagine it.
i got mouseware installed and it keeps messing around with the buttons and i must use the installation cd for my keyboard for it to work.
if i download the latest setpoint or upgrade to it all hell brakes lose.
name='Eguy' said:Setpoint is the best software I have ever used and never had a problem with it
Raven said:anything newer than version 2.3 and my keyboard starts acting up so i wonder what to do when i get me a new mice.
would hate to get me a new keyboard and afraid a logitech mouse wont work for several different reasons.
name='llwyd' said:logitech are somewhat over-rated imo. my headphones packed up after a week or two, as did several of their products in the past.
