I was curios if i got a Alphacool NexXxoS UT60 Full Copper 280mm
Alphacool NexXxoS XT45 Full Copper 240mm. would that be enough to water cool a 3770k with a 4.5 oc and 2 660ti? here is a list of my pc parts and water parts.
Asus maximus v formula, cpu, 3770-k, mem, corsair dominator platinum 1866, 16 gig,, 2 samsung sdd's, 1 WD 1tb hdd, corsair ax 750 power supply with corsair custom black braided cables, 2 660ti gpu's EVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB ASUS GTX660 TI-DC2O-2GD5 GeForce GTX 660 Ti 2GB. and a cm storm stryker case.
list of WC parts to Oder,
*** HOT *** XSPC Raystorm CPU Waterblock - Intel
- Fitting Size 1/2" Barb for 1/2" ID tube $49.99
Monsoon Free Center Compression Fittings, 1/2" x 3/4" Six Pack - White $38.99
*** NEW *** PrimoChill CTR™ Compression Tube Reservoir System - 120mm Frosted $45.95
Alphacool NexXxoS UT60 Full Copper 280mm $77.99
Alphacool NexXxoS XT45 Full Copper 240mm $53.99
*** NEW *** Mayhems Pastel Blue Berry Concentrate - 250ml $43.90
*** NEW *** PrimoFlex Advanced LRT 10ft Tubing - 1/2in. ID X 3/4in. OD - Crystal Clear $24.99
Monsoon Free Center Compression Fittings, 1/2" x 3/4" Six Pack - Red $38.99
Performance-PCs Über 655 Fully Modded (D5) 12 VDC Water Pump - Blue
- Fan Controller None
- Pump Type MCP-655
- Nozzles Pair of Monsoon Free Center Compression Fittings, 1/2" x 3/4" - Blue
- Cable Sleeve in your choice of colors
- Sleeve Color Red/White/Blue
- Heatshrink Color Black $203.95
Bitspower BP-MVV-BK Mini-Valve - Black Sparkle $18.99
Bitspower BP-CLTAC-S2 Crystal Link Tube Set For 2-Slots- Multi-Link Adapter Set Add Pair BP-BSWP-C47 G1/4" Black Sparkle Multi-Link Adapter $15.94
4-Pin Molex Powe Adapter Cable w/ Remote On/Off Toggle Switch - 36" - Sleeved
- Cable Manufacturers Sleeving
- Sleeve Color Black
- Heatshrink Color Black $5.99
*** NEW *** Cougar Dual-X 120mm LED Case Fan - Blue
- Heatshrink Color Black $39.90
*** NEW *** Cougar Dual-X 140mm LED Case Fan - Blue
*** NEW *** Mayhems Dye - 15ml Blue
- Pump Type MCP-655
