New Case for a new build
Hobojew
Hello mates.
I currently have a issue choosing a case for my new build.
The specs inside are going to be
Asus x99 Deluxe
i7 5930k
Corsair dominator plat 32gb.
GTX titan X
Intel 750 SSD and some other ssd's
Closed watercooling or custom, havent decided yet.
AX860i PSU
and my own custom sleeved cables.
Doesnt matter if it has 5.25" bays or not.
Would love to get some advice for you guys.
Note: Have been looking at In Win 805C, Corsair 760t and Air 540.
Edit: Case have been choosen..
NZXT H440, Enthoo Pro/ Primo, Define S?
I don't know, i have grown tired of the Fractal series, Its to little change to be honest.
Never actually been a fan of the NZXT cases either. but how are the watercooling options in the Enthoo case?
i can speak for the 760t being a fantastic case to work with, i would however be tempted by the InWin as i really like the design choices.
Is there alot of room for rads in the 760t and how is the air intake? Have noticed that there is no possiblity for a roof mounted radiator in the In Win 805c at least.
I have a custom loop in it only cooling the cpu atm but the case itself is awesome for the price and its fully moddable as its all screwed together and was a pleasure to work with :) there is room for a 420mm radiator at the top and a 240mm at the front if you take the hdd cages out and you can put a 120mm at the bottom and back and it comes with a pump mount bracket .there is plenty of room for cable management and the build quality is really really good for the price.
[/url][/IMG]
[/url][/IMG]
Looks pretty neat, but i feel like the side window looks a bit small IMO.
Have you modded the case any or is it just standard?
Budget isn't an issue, just thought I should mension it. :)
But if it were bigger you'd be looking at cables and... cable management grommets... and hard drives. Or just general empty space?
I only have a Intel 750 pci-e NVME SSD and two intel 335 SSDs. so harddrives isnt really a concern. Not thinking of getting any 3.5" drives.
Well, what did you choose?
Was at the local IT-store and testet alot of cases. Actually went with the Fractal Design R5 despite what I said about it. Went with the white edition with a side window.
REASON: I chose this because I can completly remove the 5.25 bays without any hasle and it has room for good water cooling to be a midi-tower..
