B browney Member Jul 26, 2007 #1 Hi, As you may have seen I've sold my DS3 so I'm after a new motherboard I'm currently looking at the P5K but are they any other boards for the same price range (£82 posted from ST)
B BUFF New member Jul 26, 2007 #4 name='browney' said: I've heard bad things about the abit IP35-E/IP35 Click to expand... such as? The only "bad" thing about them is the start-stop-start behaviour on a cold boot (doesn't do it during a restart) & that may be fixed by a new BIOS. I can find you complaint posts about the Asus & Gigabytes too if you want ... There is no perfect mobo.
B browney Member Jul 26, 2007 #5 I'm sure there are things with all boards but overall it seems the P5K is better
C cuprasport New member Jul 26, 2007 #6 id try and stick witht he asus if your overclocking they seem to give better results, the best bang for buck board is the p5k-e but if you dont want crossfire or wifi the basic board will overclock fine
B BUFF New member Jul 26, 2007 #7 I think that you'll find that the P5K has more Vdroop & lower usable voltages (only 2.1 or 2.2V for Vdimm iirc). It also doesn't have ICH9R if you wanted it whereas the IP35 & DS3R do for similar money.
B browney Member Jul 27, 2007 #8 I think I'll go with Abit IP35 (Socket 775) PCI-Express DDR2 Motherboard
F FarFarAway New member Jul 27, 2007 #9 I have an IP36 Pro and it's worth the money. Awesome board. Review very soon
B browney Member Jul 27, 2007 #11 name='Kempez' said: I have an IP36 Pro and it's worth the money. Awesome board. Review very soon Click to expand... Ah nice one the pro is a little over what i want to spend though
