New Akasa 62 :)
Gangster
Hi all,
Got this fromm a great member on here FireLORD;)
Came with all the uv guddens :D
Love the case to bits really, by far the easiest case ive worked in!!
Heres some pics, as you can see not totally cable tidy at the moment :p
I also need to order a window, and get myself a new cd drive and some UV braiding!!
Outside:
http://img126.imageshack.us/img126/8349/img00256vd.jpg
Looks really nice, and has 120mm which is always nice. id get one but i don't want black.
hehe cheers :)
Im actually surprised how big it is comared to my old wavemaster!! lol its also longer :)
Im not complaining though, working inside it is a beauty!
i've got a cm stacker, and these dont come up too bad against the stacker, only thing is lack of floor for w/c, but then they are easier to use 120.3 at the top. very nice
GangstaR said:
Hi all,
Got this fromm a great member on here Firestorm;)
Ahem Firelord :p
If you look at that image look at the IDE cables and how they snake behind the board through one of the holes on the mobo tray. This is alot neater and better for airflow
Then everything gets shoved behind and out of the way
ah yeh! my bad only remembered your sig
I dont understand when you say to put the 120mm (antec) fan behind the mobo tray, as i dont know where to like slot it through (if you know what i mean)
Cheers FireLord ;)
Right I put the fan cable down between the board
Look at the attachment I have just drawn :p and you'll see where I mean. Put the cable under the motherboard between the I/O Ports and PCI blanking plates.
Can just make it out on the bottom pic. Just below the bottom I/O bit (NIC and USB) and above the GFX card. Its blue braided
attachment.php
That cable tidying method looks an awfull lot like my method used on <Project Blooli> Firelord :p. Just has a LOT more cable ties lol.
Looks like a nice case, may have to look into gettin me one but I want the full on original SR-71. Not sure if it's gonna happen but we shall see, then there will be another new project :D.
Cheers
Boardy
