Neoprene+ Prit-Stik
K404
Hey peeps!
Almost finished my new Custom CPU hold-down but need to get the neoprene onto it.... is Prit-Stik ok? Will it eat into the neoprene and/or not stick properly?
Cheers!
K
Maybe a noprene 101 should be set up on the forum :)
lol you and your crazy mods. Keep up the good work. At a guess I'd say prit-stick would be fine if only a bit messy.
Yep solvent free - I just used the Power Pritt Gel on some neoprene and it seems to be okay :)
You can just use dielectric grease between layers...
From Mavs post in the custom-gasket thread...would the dielec break down the neoprene? I dont think many dielecs that we would use are petroleum based, but theres prob a few. If I REALLY thought my dielec was petrol-based, and I was smearing my socket and CPU with it...I wouldnt be so happy :)
K
Standard Mach evap head temps. -70 is ya believe the LCD :p . Seeing as the cold part isnt in direct contact with any prit-stik, it should be ok. I think :)
