Needed coolant for my build
paultje162
Dear overclockers,
I recently build my new PC with a custom waterloop. This is what i got:
D5 Pump
XSPC Front Bay Resevoir(2 bay)
360 Rad in the top 25mm thick
120 Rad in the back 35mm Thick
EK CPU Block
There is a total of around 1 to 1.5m of tubing.
How much liters would you guys reccomend me to buy?
Greetings, Paul
If there's no GPU in the loop too - I really wouldn't bother putting that 120mm rad in. The 360 alone will be more than enough.
I'd get 2 litres - 1 should probably do it, but you may as well have some spare.
Thanks for the info. I will remove the 120 and make it as clean as possible. For now there is not a graphics card in the loop. Maybe later on a will buy a block for my 7970. Will the 360 rad be capable of cooling them both? I still have a spare 240 that i can put in the front.
