midicronica
Hi,
I've actually been long overdue for cleaning my loop. I'm going to be changing my tubing and rinsing out the rad with hot distilled water/vinegar mix but for my pump/reservoir would it be ok to use the same mixture?
The problem is, my pump is one of those XSPC 2 in 1 reservoirs where the pump sits inside the acrylic box reservoir. There's some stuff in it too so I'm not sure how to get it out. If I just left distilled water/vinegar mixture inside of it over night, would it damage the pump?
I was planning to do that for the CPU block and fittings as well, just let them soak over night. Was just wondering if this would be appropriate.
Thanks!
Thanks!
