Need help buying PSU cables
warrenty13
im going to be buying the corsair RMX 850 w moduler psu
but will be buying some BitFenix cables , im confused on what cables i need to buy
specs of the build are a
AMD Ryzen 5 1600
GIGABYTE NVIDIA GeForce GTX 1080 G1 (which i belive has a single 8 pin)
ASUS ROG STRIX B350-F
i dont think this effects cable but corsair vengence (2 x 8 GB) DDR4 2400 MHz
a SanDisk SSD PLUS 120 GB
a WD blue 3 TB drive
all in a NZXT CA-H442W-M1 Mid Tower PC (which i belive has a fan box on it that has 10 fans out?ill be just using the 3 case fans)
a be quiet shadowrock 2 cooler
so i want to buy only what i need with these
https://www.amazon.co.uk/gp/product/B004GHD172/ref=ox_sc_sfl_title_8?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE
so if some one could give me a list of the cables i need that would help a huge amount
since those are extensions you'll just pick the color you want at min you'll need a 24 pin 8 pin for mobo and 8 pin pci-e if you want sata and molex's you'll need enough to handle the drives and accessories you add.
