Need a bit of advice with my new build
lemonjuice
im going to get a
i7 3770k
H100
64mb 1TB sata3 HDD
CD drive
what I need a but of help on
PSU (modular)
Case (space at top for dual rad)
Motheboard (Z77 Chipset though)
Graphics card (not sure to get old 6870 or newer)
i got a budget of £1000 and I'm going buying it from scan.co.uk
anyone got a idea of what i should get?
Many Thanks
Jonny
haha good question i should of said well playing games and coding with a bit of Photoshop that's why I going for a i7 3770k
games like battle field
also a little but of Virtual Mashines
psu : corsair ax/hx 850
case: Shinobi would be fine or something bigger like switch 810
mobo: ima big fan of asus boards so sabertooth :3
gpu: msi 7770 power or 560ti(both pretty much minimum for 1080p high settings bf3, although my gtx 460 does 60 constant 1080p at ultra)
It's an unusual suggestion but you might want to have a look at the asus p8z77 ws mobo, gpu gtx 670 or 680, psu corsair ax750
Ok then, in that case how about this list of parts here:
CPU: 3770K
CPU Cooler: H100 (or something like a NH-D14 or a Coolermaster Hyper 212 Evo if you wanna save a little wonga)
HDD: WD Cavair Green 1TB
Case: Fractal Arc Midi
Mobo: MSI Z77 GD55
SSD (Boot drive): Corsair Force 3 60GB
RAM: Corsair Vengeance 8GB 1600MHz 1.5v (or Vengeance LP if you choose an air heatsink)
PSU: Silverstone Strider ST60F-P, 600W 80 Plus Bronze
GPU: Asus 7870 DirectCUii
Adds up to a smidge over £1000
CPU: 3770K
Mobo: MSI Z77 GD55
all good but i would still go for a gtx 670 or 680
ye I think this sounds about right
i got a ocz agilty 3 atm so that will knock 60 quid off
CPU: 3770K
Mobo: MSI Z77 GD55
good point, the only way i can get close to the budget is buying from dabs and ebuyer
That's a good point actually. OP defo check out other sites like Aria, Overclockers.co.uk and Dabs to see if you can get a better price or not. But definitely order everything from one site, it's makes it a LOT easier
Ok sounds good, that would make it all about £980 in total
would be better if i got a gigabyte board and also are the fans quite on the case
as my current pc i build is loud lol
The case fans are super quiet. Also, no stick with the MSI board as it's one of the best Z77 boards on sale and is most definitely the best value for money board.
Also, if you want a quiet rig i'd recommend either buying 2 new fans for the H100 as the stock fans are noisy (something like Akasa Apache's would be perfect), or alternatively you could go with a NH-D14 as it's super quiet. But if you do go with a D14 you MUST buy Vegeance LP RAM because the normal Vengeance RAM won't fit
ye i was thinking of geting some better fans for the H100 and do you know any good cases with a window?
How much extra could you spend on the case? The Arc is £70, so it's good value
Btw you could mod a side panel window in the Arc if you felt up to it, that's always an option too
I think your best bet would be something like a Corsair 600T or 650D. I do believe they can fit H100's in the roof, but i'm not 100% sure, can't quite remember if they do or not
