SparkleDJackson
Id say its not that dear and you prob can get it in b&q. If its not sitting somewhere obv near the paints just ask one of the guys in the bright orange aprons
Blargh.
How much is said glue remover and where can I get it in the UK? I got my last lot of paint from B&Q
I used nail polish remover and bandageglue remover. Took maybe 15min to wipe it off on each card. Can get it in the drugstore or at the supermarked.
Okay. And the thermal pads would work after removing the shroud still or?
Yes they should work. Just make sure they dont fall off or get misplaced.
How are you sanding your parts? Sand blaster?
Thanks. Out of curiosity are they just solidified thermal paste or small silver slabs or something?
Looking good, I'm enjoying what your doing.![]()
Good luck with the sponsorship mate, you deserve it.![]()
Yup, totally agree. With the time and effort you put into your work Gigabyte should definitely consider sponsoring you.![]()
Awesome mate. That CPU Block is the best looking block I have seen.![]()
