My Gold --- update: Light effects
Dye colour option for the loops.
  • Total voters
    28
Hey is this gonnna be a lga 2011 x79 system
Suports 2011 socket but no info about if it suports x79
Edit. 2011 is the x79chipset
, so yes it suports that.
That's the only CPU block that I've looked at and felt like i needed to own it, even though I haven't got a w/c rig.
Yeah it is amazingly designed. Really like the led bulbs also, and that you can just swop them for a new theme. Seems like XSPC is getting big in the watercooling business. Got a quad xspc radiator also(recomended by performancepc's.com), so im looking forward to see how it performs.
Ordered blue o-rings, fittings, stop plug and angle adapters tonight. The Raystorm cpu block, tubing and Swiftech HydrX Coolant are also ordered from USA.
Tonights order cost 213$ + 40$ in shipping. Those compression fittings are very expensive, but they are almost everlasting?
Another nightshift coming up, but im gonna try finnish the second gpu when i get home early tomorrow morning.
Heres what ive ordered tonight(- o-rings)
Wow, looks cool.
Yeah these should fit nicely in with my mods. I believe i almost got everything i need now, except the Sandy B-E MB and the new cpu. Some minor things like more wood materials, glassplate and some destilled water, i still need to get.
Got reply from Gigabyte. They dont sponsor personal projects.
That's too bad my friend; sorry to hear that they don't sponsor projects like this. It would be so cool if they did though. Maybe you could try showing them what you're doing and what you expect out of this project?
Many, but apparently Gigabyte does not. And it didnt cost me mutch just to check if they did!! So please go laugh elsewhere
Dude i wasnt laughing at you. Id love to find out who did so i could save myself a few pennies on my £3k x79 kepler build. So i was being serious in a light hearted manner. Im not a douchebag i assure you. We are brothers in x79
Those fittings look awesome
. I've seen a lot of projects and have never seen any sponsored by Gigabyte. You should try contacting other companies, I'm sure you will get sponsored. You deserve it mate
I might have misinterpreted you. Good to hear that you didnt mean anything with that.
Tx m8.
Looking absolutely fantastic so far mate, I never thought I'd see someone pull of gold in a pc, never mind pull it off well
Both gpu's done now. Will post a few pictures a bit later today. In the meantime il go to the hardware store and get some materials for the parts to come. Will start with the top sides and fit the radgrills on. Need to drill holes, cut out for quad 120mm fans. Will also try and tap out the plank for the the radgrill. Dunno the word for it, but we say its in "flush" with the surface.
Sounds great; can't wait to see what it looks like.
