My Gold --- update: Light effects
Dye colour option for the loops.
  • Total voters
    28
Amazing work, Sir! This is worthy of job of Adeptus Mechanicus! This machine is the glory to the Omnimessiah!
Honestly. It looks so great. I can only imagine how many power you have put into this Golden Throne.
Just a peek of how the black will look with the gold painted parts. Im almost done on the inside with painting. Gonna clean the apartment today and also start with white paintin on the outside. Tomorrow i can start to screw on acrylic, radgrills and fit the fancontroller and I/O control. On top of it i will use a gasket to prevent sound, dust and also not to scratch up the reinforced glassplate.
Oh and thanks for all the good feedback, its mutch appreciated.
First coat of white half glossy paint on outside and a sata cut out i totally forgotten about :-)
Need to paint those 3 cut outs. Its a bit dusty after the filing and sanding.
Wet paint! hoping i will get 3 coats on the outside today.
I have a feeling that i missed some vital info. Why is it so darn big? o.O
Another thing, my local pizzaplace has the same chairs D:
It got normal desk size 150cm, and It will have 2 x quad radiators. The two chambers will prevent hot air to spread and its made that big because i want to install/remove fans easely from the radiator. Once the psu ,MB, HDD's, resorvoirs, fans, controllers are in place you will see there isnt a lot of room left. And i really dont want it to be or look like a HTPC.
The chairs are nice and affordable. I bought them at Jysk here in Norway. I actually use one at my pc spot but i am going to get a nicer chair for that. My old one fell apart earlyer.
Painted some screwes for the acrylic, motherboard and the ledcontroller acrylic piece.
Also made two holes for some of the leds i will soon make. This two holes with leds will light up the I/O shield, gpu and soundcard backside.
Ive finnished it on the outside. Only got those sata cut outs left to paint, but i will do it tomorrow since the white isnt dried yet. Im pretty exhausted now from working alot lately. Both of my favourite ladies got back from easter holliday tonight, and i picked them up at the airport. It was so nice to see them again
Tomorrow you will see some acrylic on the front and all of the radgrills on. Also starting to work on the hidden lightning system.
Thanks for watching and commenting.
I've absolutely loved reading this project log, and I have to say...you are doing an absolutely amazing job. You're clearly very talented and have put a lot of effort into this build and it's showing
I designed a 3D model of a 3XS Swordfish inspired 'compudesk' which I posted in the 'desk/workspace' section of the forums. I love the idea of PC's being a singularity with your workspace. Functional, but also a piece of art
Love it pal, keep taking lots of photos, and I look forward to seeing the finished masterpiece
hey dude whats the clearance for your legs gonna be. thats why i changed my design. im not being a downer on you mate its just i cant see if there is a recessed are for your legs to go into or if your arms ar going to be way high in the air. im just saying those are a few of the problems i ran into in the design process. p.s. it looks fantastic
gold on the black really stands out and looks awesome
Looking epic mate, keep it up!
Thanks. Yeah i think black, gold and blue will be a killer...
This is just epic mate keep up the good work and passion thats going into this!
Thanks Beattie.
This is just beautiful. All these custom builds inspire me to do something with my Silverstone fortress.
Yeah this forum has many good modders with nice projects.
Thanks. Ive looked at the Swordfish and its a stunner.
O_O absolutely amazing!
Thanks.
Its custom designed for me, and my feet. The desk hight is normal 75cm and my arms will be relaxed on the top of it. I meassured it out based on how i sit now at my current desk and high diner chair. My feet will fit underneath with no problem. My best advice is to find your own solutions that works for you
I have fitted the radgrill on the right side, but i need to paint more screwes for the rest. Will fit the acrylic while i am painting more screwes :-)
