Hi all,
After buying this (£600 maximum budget) pc in december and assembling it, i just threw it all together and basically played games until yesterday when i thought i had better try to tidy the insides up a bit.
After a few hours yesterday of sorting out my cables i realised just how much work goes into cable management.
I used nothing else except what i had lying around from old pc's i had, but i think i should maybe buy some extension cables for most of the connectors especially for the hard drives as they look cluttered.
Dont even ask what it looked like before i started to try and get the cables neat.
My rig specs are,
Akasa Infiniti Zor
Asus P5ql pro (p43)
Intel E8400 (oc 3.6ghz air)
4gb Kingston 8500 (1066mhz)
POV Maxcore GTX 260 216sp
Artic freezer 7 pro
Soundblaster X-fi xtreme gamer
2x 80gb ide in raid0 (on ide raid controller card)
4x 160gb sata
2x 60gb sata for operating system dual boot (vista + xp)
It is used for games and media.
All things considered for my first attempt at cable management was it worth it?
My rig specs are,
Akasa Infiniti Zor
Asus P5ql pro (p43)
Artic freezer 7 pro
4x 160gb sata
