mightynimrod
Hi ya fellas, just wondering if there are any tips/tricks you can provide me with the above setup and installation of my Mach II
Ive already installed it but i want to check that it's all fine and dandy.
My evap head is running at -53 idle rising to -33 under load.
I sprayed the rear of the motherboard with pcb laquer before i installed it.
I used 1 layer of seal string around the rear mounting plate and 2 on the front along with 2 circles of string around each of the screw holes.
I also put Alumina in the cpu socket and AS Ceramique between cpu/head
Just want to check that everythings o.k on that lot.
Now my motherboard temps report cpu temps as 45 degrees when im in the bios - i know that the board has issues with temp reporting anyway but can any other users confirm that there's does the same???
Ive also used MBM5 using the Neo 754 config as i suspect they have the same temp probes, although i dont actually know this.
On a plus note im running my A64 3500 at 2740mhz 11x249 4xHTT 1:1
burning it in atm.
Cheers for any comments fellas
Ooh whats the best grease to use in the socket btw?
burning it in atm.
