Moving monitor ~90 degrees in any direction makes PC crash
Nathlm
Yeah so I got my monitor a month or so back and it started to do this. It did not do this with my other monitor which wasn't a 3D one which may be the problem.
I've tried searching google for hours however I have no luck finding anyone with the same issue (the closest I got was someone with a laptop screen when they moved the screen it would blue screen, but there question on how to get it working wasn't answered).
Hopefully one of you guys have come across this issue before and can help me.
Monitor is an LG D2342
Thanks in advance.
When your PC crashes does it blue screen/freeze/screen goes black/something else.
Also how do you have it connected to your computer, what cables go between your monitor and your computer.
Ok so what I've found is that it goes black but also blue screens, because after it has restarted itself a window pops up saying it has blue screened
Edit: also it's HDMI and that's it
Do either of the cables move where they attach to the monitor when you move the monitor?
Also could you try using other cables like DVI or VGA?
sounds like the HDMI cable is loose in the socket and when rotated, the signal
is feeding back into the card or the internal harness may have a similar issue.
i hadn't tried hot-swapping a HDMI monitor to see if the same error happens.
but to me it sound like a feedback issue not a signal interuption error.
airdeano
does it actually crash? my best guess is loose cable or pins are worned out and move around, eithe check all cables and replace if encessary
