Mouse Pad/Mat
Pugsport
Member
well first off im not sure if this is the right place to post this of not but i could not see a better fitting place for it.
so guy and girls im after some advice on a good mouse pad/mat as my mouse dose not track to well on the SteelSeries one i have. im unsure if its an issue with my mouse or if its the mouse pad/mat im using, so i thought change the mouse pad/mat first and see if that sorts the issue out and if not new mouse time
the mouse im using is a Mad Catz M.M.O. 7
Corsair's soft mats are brilliant, or if you want a hard mat I love the Mionix Propus 380 I've got, you might too ~
However, if this a steelseries qck series mat you've got, it's very unlikely to be a problem with that, since it's utterly plain black with nothing to prevent tracking... try it on a desk or a notepad and see if it's the mouse first :)
as a lover of super-thin mouse mats, nothing touches the Razer Sphex for me. It's not as massive as others, but it's effectively as thick as a sheet of paper and very nice to use :)
The XFX Warpad, Best mousemat I've ever used and brilliant for your wrist, Protects nicely against the edge of the table and super smooth :)
Width 35.5 cm
Height 43.1 cm
images
thanks for the advice people and sorry for the late reply.
it turns out its my mouse mat after all so just need to get a new one ordered asap
