Motherboard dead ?
GLN
While my Rig was running I plugged LEDs into my sata power and then the system suddenly shut down
The power light is on the motherboard but it's just won't boot up
Dead motherboard or dodgy power supply or something else ?
Thanks
you should Never plug things in while you rig is running unless you are confident mate my advice is unplug what you plugged in and go from there
:D lol I know just before I plugged it in I was thinking I should really turn this off but owell, then quickly regretted it
Eventually got it going again after trying to boot it 50 times it just started working again
It's a old motherboard that been in a few builds now so thinks it's staring to turn a bit delicate
