Most Effective Air Cooling for BFProdigy
EddWills95
As shown in the picture thats my current set-up
And I've got this as the following speed set-ups
230mm Intake - 7v
Top Stock BitFenix Fans - 5v
Rear Exhaust - 5v
The Push Pull SP120's are connected the the motherboard and am using the Fan Xpert thing to set them as slow as I can.
Just wondering if anyone has had any of their own experiences...
I'm trying to get this as quiet as i can and it would be good if i could get rid of some fans as that would surely cut down on the noise.
Many thanks once again guys
Edd.
Edit: The Drive Bay at the top isn't there as i've taken mine out. this was just a good picture that shows the side on view of the case ;p
It's better to have more intake than exhaust, yes. But you have like... 4 times more intake than exhaust! That one fan can never pump all of the warm air out of the case like that!
What about slowing down the front fan to 5 Volt and setting the rear fan to 7, or even 12 volts?
Edit; Or take out the top fans and let the heat passively exhaust out the top...
You could leave the front and rear at 12v and the tops at 5v if you want full cooling power at quiet speeds(assuming at 12v they are quiet).
