K kenny01924 New member Jul 17, 2014 #21 YouWhat said: The politicians have to get their greedy little mits on everything thats why the VAT is so damn much here, it helps pay for their 2nd and 3rd homes, and their holiday homes inthe Bahamas Click to expand... I agree
R remember300 Active member Jul 17, 2014 #22 dont forget claiming £10 for a pack of walkers crisps and to clean their moats ...
Wraith Bettyswollocks Jul 17, 2014 #23 Well after mucho searcho of ye olde tinterweb, RS Components is the cheapest I can find in the UK.
Dicehunter Resident Newb Jul 17, 2014 #24 Wraithguard said: Well after mucho searcho of ye olde tinterweb, RS Components is the cheapest I can find in the UK. Click to expand... And yet still vastly overpriced compared to importing from the states Appreciate the effort though
paulstung New member Jul 17, 2014 #25 not very cheap but, http://www.specialtech.co.uk/spshop...ers-Mesh-with-2mm-Holes--Black-pid-16093.html Plus they only have 1 sheet in stock. What about Amazon, there is a storefront called Metal Off Cuts, I bought a few small pieces of ally in the past, their stock is always changing, if I remember most of the time the width was almost always 250mm and they had different sizes. http://www.amazon.co.uk/Metal-Off-C...628525&sr=8-1&keywords=perforated+steel+sheet If that isn't big enough go to there store front you might be lucky. Last edited: Jul 17, 2014
Dicehunter Resident Newb Jul 17, 2014 #26 paulstung said: not very cheap but, http://www.specialtech.co.uk/spshop...ers-Mesh-with-2mm-Holes--Black-pid-16093.html Plus they only have 1 sheet in stock. What about Amazon, there is a storefront called Metal Off Cuts, I bought a few small pieces of ally in the past, their stock is always changing, if I remember most of the time the width was almost always 250mm and they had different sizes. http://www.amazon.co.uk/Metal-Off-C...628525&sr=8-1&keywords=perforated+steel+sheet If that isn't big enough go to there store front you might be lucky. Click to expand... Thanks for looking but both never have the sizes or styles I want
