Yeah thats right, these cpu dont ahve the IHS they are naked with jsut the core showing, i dont think the normal HS fit cos of the size difference, i knew the old thermalright slk948U would fit but they are no longer made (these was a screw down HS with a backplate so was ok), and the new ones dont say nothing was hoping soemone here had a air cooled system...
