Ok, i'm just going to start out by saying that there would be no benefit in mixing biocidal agents like that. It won't do any harm, but essentially, you'd be wasting money... It's kind of like buying two mice for the one PC: they will both work, but sometimes they might interfere with each other trying to do their job.
Also, with Silver Kill Coils, you don't need more than 1 piece. You can insert more, if you wish (sometimes done for looks), but 1 is all you need!
Final point: if you go the kill coil route, you *might* want to add some anti-corrosive, because you would be introducing a mixture of metal into your loop, which can lead to corrosion over the long term (note: Galvanic corrosion is really bad, but that is not the type of corrosion I am talking about here).
Now, IF you run a copper or nickel plated loop (i.e. all your blocks and rads are copper or nickel plated (i.e. the same)), you will still get corrosion whenever you change the water. Adding silver to this type of loop will add a tiny amount of galvanic corrosion (due to dissimilar metals, but the weighting of silver is close to both nickel plating and copper, so it's almost negligible), and adding an item which will change the ionisation properties of your liquid, which CAN change its corrosion effects on your blocks as well. This can be counteracted by anti-corrosives - which in and of themselves are pretty toxic in nature.
Personally, having done a lot of reading about this, I would not bother with anti corrosives, because they often introduce more complexity into the liquid than they are worth. But then again, I am also taking great care to ensure that all my blocks are the same (all copper in my case), and as such I would NOT introduce another metal into my loop (i.e. I would use something like PT Nuke as a biocide), but that is after researching and taking time and care in my part selection.
I will edit in the link I have on corrosion shortly, so you can read up on it too!
Link 1
Link 2
